ItzGenX »
https://forums.nicoclub.com/itzgenx-u1074.html
Thu Sep 30, 2010 8:43 pm
You have a build thread of it? Pictures and methods help with the ideas on the easiest yet proper ways to do some of it. Right now in my head, I know what I am going to do, but sometimes the plans change once you crawl under the car and try to execute that mental image. I haven't even placed the front subframe underneath the car yet to see if it has any 'guide' holes that may help line the sucker up. After I get it bolted up, I should be fine the rest of the way since I did weld up an alignment apparatus for the strut towers. The rest is just laborous drilling and welding (easy part). I plan on keeping the S14 rear subframe. I am just going to swap off the whole spindles and diffs/rear cover, replace hicas ball joint with a non-hicas z32 bushing, etc. Then go clean off the surface rust and spray everything down under the car after I swap the floor pans for the transfer case (if needed). The rest is just wiring and dropping in the motor + welding a transmission mount bracket. I basically just "wing it" as I go to be honest.
