livestone »
https://forums.nicoclub.com/livestone-u26640.html
Tue Mar 08, 2005 5:28 pm
Well to solve you little problem, with the greatest of ease and without fear of blwing anything up you can use a relay. Use your light switch, or radio power, or key acc wire for the switch part, then run a standard 12 gauge wire to the relay from the battery, it will provide enough power for up to four gauges, if you need more gauges then add more relays and piggy back the switch and battery wires. the realy will hook up exactly like the relay for after market drivings lights.
