Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Mon May 20, 2013 7:31 am
Did the car have A/C originally? If so, then you need to find a way to mount the KA compressor to the SR block. CodyAce has some conversion brackets, just do a search in the RWD SR forum. Another option is to modify your existing KA bracket to bolt up to the block. I've seen people take the SR bracket and bolt the KA compressor to it, but you can only get 2 or 3 bolts secured, so I don't really recommend it.
If your car didn't have A/C to begin with, then you're in for an uphill battle. The HVAC control will need to be changed, you'll need the A/C box for under the dash, the compressor, the drier, the condensor, the lines, and some wiring work.
