audtatious »
https://forums.nicoclub.com/audtatious-u2438.html
Tue Jan 08, 2008 8:02 pm
You can run the power wire down the drivers side. Back of the engine bay in the far corner (behind the drivers strut tower) there is an area to pass a power wire into the wheel well. From the wheel well you can have access to the rubber donut that all the wires pass through into the interior (behind the fuse box under the dash).
You will need to pop out a portion of the inner-fender liner to get at it, but there is no cutting and no holes needed this way.
