hooked up safc2 and now car wont start
240cp
Car: 95 240sx
ive got 95 240 supercharged with itbs and intercooler wired in the safc2 today and it come on did the initial setup and all and now the car wont start it is not getting any fire cant figure it out acts like it jumped timing cause it fires every 6 or 8 strokes can someone help
Florida240sx
Was the car running prior to safc install?? Sounds like distributor is off a tooth or possibly 180..
Florida240sx
The only wire you should of cut was the mafs wire, which if it's cut the car would still start... everything else should of just been tapped into for signal...
240cp
Car: 95 240sx
yeah the car was running but real rich then i had to leave town for a week when i got home i tried to start it and it tried to start and ran real rough then completely quit also it was running on stock ecu and injectors
WDRacing
What exactly is your setup? Injectors, fuel rail, fuel pump etc. It'll help troubleshoot.
WD
240cp
Car: 95 240sx
right now sc, 370 injectors stock pump and ecu with safc 2 rb20 side mount intercooler custom plenum getting rid of itbs for now and putting the stock throttle body back in the intake side of the sc i know its not the best but thats all the funds will allow for now
WDRacing
Let us know what happens once the singe TB is back in place.
Craving4Boost
Car: 91 240sx fastback
did you tune for the 370cc's at idle rpm
240cp
Car: 95 240sx
na at the time i didnt have them in it was all stock minus the sc, throttle bodies and plenum
240cp
Car: 95 240sx
i need to post pics of the final product but i dont have any right now but as it stands right now i have the supercharger under then mani and itbs with a plenum put the iacv and the aac valves on the plenum and wired everything as normal minus the throttle position sensor i spliced them together using the stock plug and the suzuki sensor when i got the safc2 wired in and did the sensor check and monitor mode the throttle was at a steady 20 percent and wouldnt come down even after i adjusted it but i didnt think that would affect it from starting i did crank on it alot trying different things could it have jumped timing
