Hooked on 240 »
https://forums.nicoclub.com/hooked-on-240-u62070.html
Tue Jun 30, 2009 5:05 pm
Lonnnnnnng story but things didnt work out the way i hoped.....REALLY put a damper on things... then i got thinking for budget builds... From the idea of going all motor... then ITB, then ITB turbo.
Then relizing i dont have enough money...
i was going to go ITB KA.
i have everything but megasquirt to get rid of the MAF.
OLD PLAN:
Right now im working on a ITB setup with some supporting mods:
-GSXR 1000 ITB's-Head work (port and polish or maybe just cleaned. Vavles and other things replaced)-Cut stock manifold to fot itbs-NISTUNE or megaSquirt to control MAF and a couple other things-Full emissions delete and EGR block off-S13 exhaust cam trick (two S13 dohc exhaust cams for 248/248 duration )
New plan: Just bought most of this stuff SUPPPPPER cheap off a friend.
-T3/4 turbo /Front mount /Greddy RS BOV/etc...-Head work (port and polish or maybe just cleaned. Vavles and other things replaced)-emissions delete and EGR block off/ things that dont need to be there -S13 exhaust cam trick (two S13 dohc exhaust cams for 248/248 duration )-Sr 370cc injectors-walbro...
just somethings to happen.
While i have the motor out. ALOT of cleaning up will be done to the engine bay. Its also gettting painted (body) Either a respray of the stock color, or go all out and do what i want, HONDA Fuji blue pearl got some other exterior things like a gp sports 3 piece hatch wing/gp sports roof wing...
Heres whats basically done to it:
Engine bay:~Intake~Megan Racing header~2.5in BRM cat back/dual tip~NGK wires/plugs~Z32 MAF/Fuel filter~Mishimoto Radiator~Batter Relocation
DriveTrain:~R32 Skyline VLSD~Synthetic Oil ~transmission Flush every 10K
Interior:~98 (S14) Cloth Front Seats~Black molded carpet~pioneer Premier deck~infiniti Kappa components
Exterior:~Painted Grills black ~No more stock wing/antenna~stock SE wheels ~5mm rear H&R spacers~rattle can black roof
Suspension:~Megan Racing Coilovers :Street Series
Some old pics to hold you over:
I have a ton of pics. When i sort them out. ill post the most current ones.
Going to pick up the "pieced together" turbo kit thursday. (All specs will be written in when i get it
-T3/4 turb-Turbo Mani + Gasket-XS Power FMIC-KA24DE(T) Oil pan + Oil line (to turbo)-10-15psi wastegate-Megan SR downpipe-Turbo elbow
What i still have to buy:~Greddy Emanage or something just for now~IC Pipping~More but i forgot
Stuff i have to do: (This is more for me as a checklist/todo list more then just for you guys )
Engine / Bay-New belts-Head/intake mani/rear main/oil pan gaskets-Wire up flex-a-lite fans-Mount interfooler and pipping-Bring head to hunts (local machine shop)-wire tuck on engine harness, fusebox relocation?-new coolant res-power steering res relocated-fix brake booster (fix rust)(more when i find my piece of paper)
So you can see ive got my hands full with a bunch of stuff. And im trying to Finish it all by July 17th... HOPEFULLY my deadline is do-able.
