hoodpins_how 2 ??
wetawded87
Car: nissan 240sx S14
im gonna drill into my CF hood tomarrow and i need advice on avoiding stress cracks and how to do a clean job ? someone send me some tips!!
CMG
Car: 1989 240sx Hatch w/ Redtop
Can you not just use the latch?
wetawded87
yea but it rattels when i pass 50mph ive adjusted the rubber spacers but it still dosent fix it.. i think ill wait a few days cause this isnt getting alot of attention and i dont wanna mess my hood up.
Unreal
I would suggest just not doing the hood pins at all. I've always found them pretty tacky
Goldeneagle
Car: 1992 240sx Coupe
Put tape on both side of the hood before drilling into hood.
The top piece of tape helps keep the drill bit from moving around and the bottom lets you know when you have broken through.
Modified by Goldeneagle at 10:43 PM 1/13/2008
98koukile
Car: 1998 Nissan 240SX LE
Another tip is put something like paint on the tip of the pin so when you close your hood on it you can see a dot on the tape exactly where the pin hits the hood. measure twice, drill once
CMG
If the hood rattles, you might be able to put some small rubber bumper things at certain points. I would never use hood pins, I've seen too many damaged roofs from hoods popping up, and even had a ford focus that had the hood slam up into the windshield and roof right in front of me.
480sx
Car: 1996 Pearl White 240sx
If you install hoodpins correctly your hood will never ever flip up like that.
I think they are tacky too, but they will definitely keep your hood down.
98koukile
I think you guys are misinterpreting the use of hood pins. When used in tandem with your stock latch it saves your expensive carbon fiber from spider cracking and splitting in the corners
amolao
Car: 1989 Hatchback (the first one...) w/ Autech sr20de S15
I agree with the use of tape to reinforced the area while being drilled. Go slow with a small good quality bit, just to start the hole. Keep the bit straight, do not force it. Ensure to mark the area of the hole by the method somebody explained. Use chalk or white out on top of the pin and close th e hood to mark the exact point. Make sure to identify where the pins are going ahead of time, there are two holes already in the hood support bar that you can just redrilled for a higher size for the pins.
