So how much is this test manifold going to be going for once it's removed??? Has to be used with a top feed inector system correct? So I'll pick up the ams fuel system with it too got my cams pistons etc from you already...Chris@AMS wrote:For anyone who is not aware of what we are doing here...
This is a test manifold that we are using to determine the proper runner length for the production manifold that we are making. Getting runners made on a curve is expensive and not realistic for the prototype manifolds. Once we find the combination we like with respectable power gains, we will be having the pieces for the runner made so that the plenum will fit nicely under the hood.
Yep. Thats the exact port angle. Its pretty steep and then add the lean of the motor and that intake is what you end up with.WDRacing wrote:HAHA, man I wish I had that problem Is that the actual angle of the intake ports? I'm sure it is, I doubt you would have ignored that. Looks really good, although I have no idea in all reality what to do with a hood. Especially if this is going to marketed...lol.
WD
Nobody wants to buy the production piece?Florida240sx wrote:That prototype be up for grabs?
