THat dynamat kit sounds interesting, I might check into that....thanksI know it gets pretty hot under the hood and it might be a matter of time before paints starts bubbling.........1991S13 wrote:When the man at the body shop primered my car he took the under liner off and I guess he figured I wouldn't miss it, so he trashed it. I bought the Dynamat kit for under the hood and I haven't had any heat problems, and it does a pretty good job cutting down engine noise.
So say you were running a SR with turbo, what should you worry about heat wise? And what should I do to prevent any problems?justmerging wrote:The engine gets a lot hotter than it would just sitting in the sun. I wouldn't worry about it too much unless you get an SR or something else(like a turbo) that runs extremely high temps.
