As if. Do you really believe all that bull****?maxnix wrote:Here's the real problem with the above solution: the hood is designed to bend and crumple in a crash.
Strengthening at that crumple point could result in it coming through the windshield and decapitating the driver. In some cases, not much of a difference, I guess.
Modern cars are like older cars as far as crashing them is concerned. All accidents are random events. What is done on a test track or crash test are controlled events seeking a specific results.qship96 wrote:Yeah, who needs seatbelts, airbags, crumple zones, breakaway steering columns, steel beams in doors, ABS, stability control, disc brakes, or even turn signals -- modern safe cars suck, right?
SO i sent ur picture to my Body Shop, they had e-mail problems so i faxed it apparently did not fax well but they got the idea.they used an aluminum angle iron, and did it on both sides, even though my problem was only on drivers side.they flipped the angle iron on the inside so most of the angle is covered by the hood pad. CAME out awsome cant even tell they did anything.goody94q45 wrote:
A lot of owners, me included, have had problems with bent hoods and many of these happened after the OEM struts were replaced with new struts. In many cases the new struts were OEM. If you need to replace the struts I think you might be better off replacing with a used set with equal, but lesser than new, compression. I sold a pair to a member that I was able to measure by compressing on a bathroom scale.
A also inherited a bent hood on my 94Q and came up with this quick fix after getting the hood painted and not wanting the crease to come back. It's not the prettiest repair I've ever made but it's functional. Ever looked at the tiles on the underside of the space shuttle? You wouldn't know it's a billion dollar spacecraft. I used 1" angle iron and had to open it up to about a 120 degree angle to fit the channel of the hood and allow it to close flush. It looks like my choice of fasteners was not the best. I'm sure there's many better ways to do this repair and improvements are encouraged.
Did I mention that all the parts needed for this repair can be found at your local Ace Hardware?
thats nice - so do i but about 8 years ago i left part of my intake on the ledge just below the strut mount and closed my hood and bent it.thus the fix..............................................Q45tech wrote:I open hood at least once per week [to check fluids] that is about 1,000 times so far. Never needed anything except a monthly drop of hinge lube.
Maybe it all started as a couch potato HOOD never getting exercised.
