danshaz82 »
https://forums.nicoclub.com/danshaz82-u67275.html
Mon Jun 03, 2013 2:14 pm
i dont have pics, but its fairly easy.
you have to disconnect the end of it where its connects to the hood latch assembly. theres a small spring that youll have to remove. unless you get a new spring, dont lose it. youll probably need to take the whole hood latch assembly off to make it easier to get to.
then you just need to feed the cable out till the firewall. i dont remember if theres bolts or screws holding the handle in the dash in place, but take those out, and then the whole cable should be able to slide right out.
install is just reverse of that
hope this helps.
