hood Rattle
qx4dude
Car: QX4
Hey guys,
I have a 2002 Qx4 and i have noticed while i am driving i can see the hood slightly bouncing up and down. The hood latch does not seem to hold the hood that tight. Anyone else experince this? Any ideas how to stop it? The latch and latch release all look normal.
Thanks.
slickroger
Car: 2001 Nissan Pathfinder
Never experienced before but
Check the hinges at the back end of the hood if your latch is good than the mounts closer to your dash may be an issue.
Good luck
Pwnin O'Brien
I have the same thing. I got in an accident a while ago and it messed up my hood latch alignment (the hood made a loud bang when it went up/down on the highway). Even after I had the latch adjusted I noticed that the hood still bounced up and down on the highway. I took it to Nissan and they said it's perfectly normal for a little up/down movement at high speeds. If you can actually hear the hood bouncing up and down, then your hood latch definitely needs to be re-adjusted.
hotkiss
Car: QX4
qx4dude wrote:Hey guys,
Thanks.
I had the same problem and resolved it by turning the two rubber bump stops at each corner of the hood to the left. If you turn them left and they'll go up about 1/2" and make a tighter seal between the hood and the frame. Hope that works for you.
qx4dude
Car: QX4
Thanks i will give the rubber bump stops a try.
Its not at high speeds but just at any speed if i hit a sharp bump i see it bounce a bit. The latch latches the hood just fine but you are able to pull up on it a little and wiggle it. Thanks for the help
fueler
Car: 2 Nissan's
2 BMW's
bada bing bada boom theres your answer. i had to adjust those on mine.
Chuck Tribolet
Car: '01 Nissan Pathfinder
'87 Chevy Corvette
'01 Toyota Camry daily driver
'98 Boston Whaler Montauk
There's two adjustments: The latch determines how far UP it goes, the rubberbump stops determine how far DOWN it goes. What you want is UP=DOWN.Do the adjustments in baby steps. In theory, if you get the bump stops uptoo high relative to the latch, you might have trouble getting the hood open.On my '01, it's trivial to pop the grill out. I think I'd do that to have access tothe latch in case it gets stuck. You might also be able to adjust the bump stopsthough the grill area with the hood down.
Modified by Chuck Tribolet at 3:30 PM 12/3/2009
Pwnin O'Brien
I did not know this, I will definitely have to give this a try tomorrow! Thanks!
