hom
Ferguson wrote:The plain metal end of the prop rod simply fits through a bushing in the passenger-side front crossmember. There is no retaining clip. If you line up the rod as it would normally lay when down, you should be able to spot the bushing very easily.
Given the light weight of the hood I don't think I'd leave the hood open when not around - any wind at all will flap the hood. I also think worse things could happen with the engine compartment wide open anyway.
ok thanks for your help.
We never get any wind, this was just a weird day, if I were at home I would have put it down. I've lifted the hoods on my last 3 trucks and one was a show truck that was in 3 magazines and I never had a problem out of them, I'd say that the Altima hoods aren't as strong though.
It's under a carport so it's not exposed to the weather. It won't hurt anything under the hood. I've been working on vehicles for the last 10 years and have yet to have an engine problem from the hood being up.
