hood pins
USCS14DUDE
Car: sports, cars
I tried searching but didn't come up with what i was looking for. My question is can you just drill into a carbon fiber hood or is there another way. I've heard that drilling holes for pins messes up the hood. Any help would be appreciated, thanks
electricproblem
i drilled into mine just fine...... just dont press too hard on the hood and start with a real small bit and work your way up......also make sure u know where u want to drill because u dont get any second chances.......
SeVa-S13
Car: '05 GTO 6spd
That sucks, carbon fiber hoods don't come with stock latches? =\
AkademikONE
they do come with latches... but due to its light weight, at high speeds, it's a bit flimsy, and it wobbles, and there's a chance of the latch breaking off and the hood flying off
Strategos
here's something that sounds even dumber: what are hood pins for? I searched once and came up with nothing.
SeVa-S13
Car: '05 GTO 6spd
It's a "cooler" way to fasten your hood down. Instead of (or in conjunction with) a traditional hood latch mechanism, you have two holes in your hood through which go a couple pins with a hole through them aswell. I think a couple cotter pins then go through those holes and hold the hood down. It's mainly for looks, but I guess can be a safety measure.
[Zero-S]
Car: Tell me whats wrong with this picture. 3 240's, only one runs.
Sec, and I'll link you to what happens when you don't use hood pins with a CF hood.
Edit: nvm, they took the pics down already.
Story: Guy on 3si bought a cf hood for his 3kgt, main latch failed at around 60mph, hood flew up, broke in half and landed on the side of the highway. Bent the two arms where the hood attached to as well. Use hood pins, please.
Strategos
thanks for the info. I was serious though you could type in "hood pins" on google and get no helpful results.
jdmfreak
Yes please do. A kid's CF hood on his 98 Lude ended up smacking the windshield. VERY dangerous and costly if you dont use pins.
