bcar240 »
https://forums.nicoclub.com/bcar240-u13477.html
Sun May 30, 2004 3:13 pm
mine used to do this too. the lock would pop, but the hood was jammed or something and wouldn't raise up, I had to take my fingers or a dowel rod and pry the hood up, and it would eventually just open up like usual so you could get under it to the safty latch. try having someone pop the hood while you are prying it up. strangely, after I had a front end collison and had that fixed it opens just fine. so I guess if all else fails, go ram someone.
