VStar650CL »
https://forums.nicoclub.com/vstar650cl-u299034.html
Sun May 25, 2025 9:19 am
I think the only way you'll get at the latch without destroying the grille is through the righthand wheel well. It's tucked up behind and inboard of the headlamp, so there may be enough room to get a hand up there. Removing the washer tank might help. If you can reach it, the latch looks to be rear-facing and you should be able to trip the lever with finger pressure.
You won't find a technician anyplace who doesn't rank stuck hood latches right up there with hemorrhoids and split knuckles. It's not likely to be easy.
