onosqv »
https://forums.nicoclub.com/onosqv-u507.html
Wed Aug 20, 2008 2:10 pm
For the sides of the hood behind the light & by the fender, there should be a rubber spacer there, you just turn that counter-clockwise upward (if it is still even there) so that the hood will sit higher once closed.
As for the area behind the front bumper in the center, that looks more like the bumper needs realignment (may be warped, or may have been bolted up crooked, or you could have tweaked bumper support/radiator support) or the passenger side rubber spacer is too high.
It's oem, there aren't too many things other than what I mentioned if the hood itself is even.
