hood gas struts dampers
roguemjl
Car: 2015 Rogue SL
Has anyone installed hood gas struts on the rogue? I'm looking for an inexpensive universal set. Thanks
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
AFAIK, no one has done this mod in this forum. So that's good news for you, because you get to figure out all the details and put together a DIY for others! :dblthumb:
itsa300zx
Car: 1990 300zx NA W/TT swap
2011 Nissan Rogue S
2008 Highlander SR5
I thought about this few years back too, will revisit this summer.
Couple thoughts:
The Rogue hood is effin heavy, would need lifts that will hold at least 100-150lbs each. These were hard to fine in a smaller shock. I'm still looking for a good spot to mount the ends.
Rogue One
2022 Honda Pilot SE
itsa300zx wrote:
Fri Mar 13, 2020 9:03 am
Couple thoughts:
roguemjl has a 2nd gen Rogue which features a lighter weight hood than your 1st gen model. It was one of numerous weight saving changes made to help the larger 2nd gen models use less fuel than it otherwise would.
casperfun
Car: 2009 Nissan Rogue SL AWD - Indigo Blue
Not universal and pretty cheap.
https://www.ebay.com/i/283069965915?
:wavey:
itsa300zx
2011 Nissan Rogue S
2008 Highlander SR5
Ahh, yes you are right, did not realize that the gen2 had lighter hood. Thanks.
Rogue One
2022 Honda Pilot SE
casperfun wrote:
Fri Mar 13, 2020 1:37 pm
:wavey:
Cool find!
According to a seller of after market replacement parts, their unpainted 1st gen hood weighs in at 63 lbs. The 2nd gen hood is almost 1/3 the weight at 23.2 lbs.
itsa300zx
2011 Nissan Rogue S
2008 Highlander SR5
:wavey:
Thanks for the link, never thought of ebay.
roguemjl
Car: 2015 Rogue SL
Yes, I ordered a set last night. Shipping from China so it may take a while. I will update when I get them installed. At least I hope the mounts work. I should be able to find different struts if need be.
roguemjl
Car: 2015 Rogue SL
The struts never showed up from China. No updated shipping details after asking quite a few times. Asked for a refund. Will look elsewhere. Don't buy from this seller. Well, he will be probably be selling the same thing under a different name.
casperfun
Sorry to hear that, I been pretty lucky getting stuff from china.
Not inexpensive as u wanted tho.
Try America :mike
https://www.redlinetuning.com/2014-Niss ... 013-03.htm
Return to “Rogue Forum”
