amc49 »
https://forums.nicoclub.com/amc49-u275146.html
Thu Jan 25, 2018 6:43 pm
You need to understand that rubber parts often take a different set as they run in to maybe need another adjust, there is absolutely nothing Nissan executive can do to change that. Simple physics that have to be dealt with on the fly. Everything in the universe goes from a state of higher order to a state of lower order, the only thing changing that is human intervention.
FYI, on my Fords I use 7/16 steel studs and Home Depot $2 furniture leg bumpers LOL, they have lasted for years once adjusted. More FYI........on my two Tempos the hood line would bend out of line from the fender line even with all corners dead even. I found out the steel hoods were so lightweight you could actually rebend the hood edges BY HAND to get them back perfect again. Pretty funny.
