Hood damper install
Nissan 350z / Nissan 370z technical discussion forum: Maintenance, performance, installations, modifications, how-to's and troubleshooting.
sluggoZ
Car: 2004.5 Nissan 350Z Touring Roadster Super Black/Black
I finally got around installing my NRG hood damper, they also make one for carbon fiber hoods. With the help of zinistr's dremel work and another buddy.
You'll need a 10mm deep socket for the body bolt & 12 mm wrench for the hood.
It's good to compress each damper several times before the install. Placing a towel on the ground & using another towel folded in your palm to make it less painful & easier to compress damper downwards.
When measuring for your dremel cut, place the removed black plastic cover and align with the tab holes & body bolt, use a magic marker making a U shape on the plastic cover next to the body bolt then just follow the lines slightly wider when dremeling.
Place some healthy dabs of bearing grease on all 4 ball joints.
Another thing about the NRG kit is that the markings of the bracket which goes under the hood, R goes on the drivers side & L on the passenger side, usually it's the opposite.
So if your into car shows, auto cross or track events or even working on your engine bay where you'll need your hood up for a lenghtly time...excellent on windy days too!
Here's some pics...
Image Image Image
kuhan
Car: 2008 Nissan 350Z Enthusiast 6spd
Very nice! I'm actually looking to buy a pair of carbon fiber version right now. I noticed you installed the dampers in the right way as well. :dblthumb:
sluggoZ
kuhan wrote:Very nice! I'm actually looking to buy a pair of carbon fiber version right now. I noticed you installed the dampers in the right way as well. :dblthumb:
Yeah, I see you placed your order with mrwong...he's got the best price! :dblthumb:
BusyBadger
Car: '92 Nissan 240SX
'05 Nissan 350Z
'13 Nissan Juke
Looks great! I've considered picking up a pair for a while now, but my priority is on the other end.
When you install some heavy duty hatch supports do a writeup/review, I'm tired of getting hit on the head when the the weather turns cold! :gapteeth:
kuhan
SluggoZ, I actually ordered the EVO-R cf ones from thezstore instead of NRG ones since supposedly no plastic trimming is needed. Plus the EVO-R ones have 2-stage opening (half way and all the way up).
BB, I have the heavy duty hatch dampers as well, but I only installed one heavy duty one and kept the other oem one. :D
It held up my Nismo V2 wing pretty darn good. But I will install the other heavy duty one this coming weekend.
sluggoZ
Great!
Post pics when you get a chance!
kuhan
^Will do. :)
z33r350z
Car: 2008 350z 299.9 whp
1994 pathfinder se fully loaded
i have the evo-r ones no cutting and they are 2 stage ;)
kuhan
I finally had time to install the EVO-R hood dampers. The install was simple and took me about 20 minutes or so.
I really like these since no trimming was required, and they have 2-stage opening, which is pretty cool.
Here are some pictures.
Unpacked
Installed
No trimming needed :)
stage 1 (for car show etc.)
stage 2 (all the way up)
sluggoZ
Looks great! :)
kuhan
Thanks, SluggoZ. :)
z33r350z
kuhan wrote:The install was simple and took me about 20 minutes or so.
20 mins damn thats a long time
kuhan
^Good for you if you've done it faster, smart one. There is something called "take your time". ;)
BusyBadger
'05 Nissan 350Z
'13 Nissan Juke
z33r350z wrote:i was young and cocky
Do not make me regret not instantly banning you when you created a new account on here after having been previously banned.
z33r350z
hey i was helping out last time when i got banned last time when a mod moved my tread to gen chat that was 350z specific. also i only came back to help promote a great new sway bar set up better then stillen.
also ive given myself 4 hours to install a hks hi power ti, hellwig swaybars, injen long tubes, and an innovate wideband. ill let you know how it turns out . im on a time budget cause i gotta get my car out of the body shop and back before the close i got somthing special planned stay tunned
Return to “350z / 370z Technical”
