hood clarence issue
supra7m2002
Car: s14
I have a rb25 swap I just got done doing, now I have a problem with hood clarence. my intake mani and pipings along the top of the engine are hitting the hood. I try the slivia hood and same thing too. my car is an 96 240. what solution do you guys have for me in helping here. thanks guys.
mello88
Car: s13
cut part of the hood skeleton out or prop the hood up with washers on the brackets.
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
I used longer bolts and nuts w/lock washers at the hinges to prop the hood up about an inch. Just make sure it latches properly because it puts the hook out of alignment.
supra7m2002
Car: s14
oh ok, what about a carboon fiber hood? do I still need to shim it too?
supra7m2002
Car: s14
i'm having problems finding a hood to fit the s14 jdm frontend, where can I buy a carbon fiber hood that has no braces on the buttom of the hood? it's for an s14 jdm silvia koukie front end? thank guys for your time.
matafied
Car: 1989 240 rb25det 1992 240 rb25det
what did you use as far as mounts to install it in your car?? i ended up using some 325i bmw motor mounts, they dropped it down just perfect.
supra7m2002
Car: s14
yea that's the problem, mines lifted the engine up a bit. that's why it's hitting.
matafied
yea you could try the bmw mounts, it will drop the engine about 1 1/2 inches. better than chopn up your hood lol
gawdzilla
Car: none
what is an "s14 jdm front end"? arent all s14 front ends sold as usdm too?
kjlindgr
gawdzilla wrote:arent all s14 front ends sold as usdm too?
Yes and no. They look the same but the JDM ones are cooler.
Darius
oh yep. I remember reading that somewhere on zilvia.net.
wawazat8402
Car: 89 Sil80- RB25DET
Theres no difference in the hoods, except the badging.
matafied
325e 1984-1987, 325iS 1997-1991, 325i 1987-1992, 325 1986-1988, 325es 1986-1987
exodus5547097
I have rb25 swap on s13. anything to help me about hood clearances. Please make any suggestions.
lucky7
Car: 97 RB25 S14
get the greddy intake manifold, or just get some E30 mounts like that guy said. looks like any E30 6 cylinder mounts will work.
exodus5547097
lucky7 wrote:get the greddy intake manifold, or just get some E30 mounts like that guy said. looks like any E30 6 cylinder mounts will work.
what is E30?
Joe
exodus5547097 wrote:
what is E30?
a bmw.
ANVIL
Car: RB25DET S13.5
those bmw mounts only for s14? which x member? never heard of people using bmw mounts
Neejay
matafied wrote:yea you could try the bmw mounts, it will drop the engine about 1 1/2 inches. better than chopn up your hood lol
What mount kit are you using in addition to the e30 mounts? R33 crossmember? Top hat/McKinney? Driveshaft?
These look very promising, as you can find the urethane version of these really easy it seems (from a quick google search.)
ST240
Car: RB30DET Nissan S13
'01 Nissan Pathfinder
i am intrigued. I was going to use the stock 240sx mounts with my r32 crossmember for my rb20 swap.
these mounts are lower profile than the stock 240sx ones?
edit i have googled the mounts and there appears to be a ton of "oem" varieties, can you show me a pic of the type you used?
Modified by ST240 at 11:08 PM 6/17/2008
ST240
bump, cmon matafied . I really dont want to cut my hood.
BoostFab
Car: S13cp, S13fb, S14z
what's wrong with trimming a few spot on your under-skeleton of the hood... don't make a big fuss about it. just do it.
