sadams »
https://forums.nicoclub.com/sadams-u27201.html
Wed Apr 20, 2005 3:30 pm
First successful maintenance tonight with one major failure. Hope you guys can help (at least some moral support). While I was trying to get my Y33 up on some jack stands (so I could get the jack "officially" under the engine cross-member) to get the oil changed I bent the radiator support slightly. The front rolled up about 1/2". The only effect I've noticed is that the hood has a little play in it when closed and sits about 1/8" to 1/4" higher than the fenders in the front. I could find any adjustment to pull the latch down and I couldn't pry the support back into position.
Help?!
BTW, successes, Mobil1 Oil and Filter, also drained the transmission and put 4 qts of fresh Mobil1 ATF in it. Took out the hard shift from 1-2 and smoothed out the transmission in general. As soon as I find a BG machine in town I'm gonna get an official flush done. Fluid was slightly darker than new. Still 12K from scheduled.
