A34D4ME wrote:I'd be willing to bet that equal length stuff is mostly BS. Reason being that the pressure will be equal everwhere in the manifold.
Wrong. You are confusing static pressure with dynamic pressure.
Because of this, you have to take flow characteristics into account.
You can see this by doing a fluid dynamics comparison of the two, where you will see the equal-length manifold vastly outflows a log.
However, I personally believe you do not need an equal length design to improve the flow characteristics dramatically. I think a tubular manifold would do just fine, regardless if the runners are slightly different length.
WDRacing wrote:Look at the fastest turbo cars ever built on the planet. The Buick Grand National. Thye used the a design that most people would laugh at. Two log manifolds, the one on the drivers side has an outlet pipe that came under the motor and attached directly to the back of the passenger side log. Which has a flange on the front side for the turbo. Most GN guys don't even think about a mani swap until they hit the 650whp mark.
Simply because GN's make great power on log manifolds does not mean there is no room for improvement. Sure they work, but they are hardly the ideal solution.
Examine a formula 1 turbo manifold from the turbo era of the late 70's/early 80's. These machines produced 1500hp on 1.5 liters!!I guarantee you these manifolds did not resemble a log.
I realize this is an exotic example, but it gives an indication to what the pinnacle of motor sports considers to be a proper manifold.
Renault RE20
And just on wow factor, the charge pipe setup:
Modified by Titan at 4:38 PM 12/27/2005
