Homemade Boost controller
I am Technoman
Car: ???
Hey Rob what are you using for a fuel system?
groundhogday1976
Car: 2015 Altima 2.5 S
Or you could get a bleeder valve-type MBC for $50 or less and it'd work better, be more reliable, and look much better.Here's a good one: http://www.dejontool.com/DSM-MBC.htmYeah, I know it's a DSM site, but it'll work.
tylerwal
^those aren't bleeder type, they are basicalled the same thing you can make yourself
http://www.geocities.com/chmwatson/FAQs/mbc.html
http://www.c-speedracing.com/howto/mbc/mbc.php
groundhogday1976
tylerwal wrote:^those aren't bleeder type, they are basicalled the same thing you can make yourself
My bad. Actually those restrict the amount of pressure the wastegate sees until the desired boost is reached, wheras a bleeder type just creates a leak so the wastegate doesn't see as much pressure.
Mikel
Ball and spring > bleeder valve.
Ball and spring will spool faster.
95_240sx
Car: My baby (car)
How does a Ball and spring make it spool faster?
Rick
tylerwal
95_240sx wrote:How does a Ball and spring make it spool faster?
Rick
a ball and spring controller keeps the wastegate valve closed until desired boost pressure is reached, unlike a bleed valve
groundhogday1976
^ Plus you aren't losing pressurized air like you do w/ a bleeder valve, so there's less lag. The ball and spring just places a restriction in the pressurized air that the wastegate sees. The ball is held in place by a spring, and when the desired boost is reached air pressure overcomes the pressure of the spring and the ball moves, allowing air to reach the wastegate.
95_240sx
Car: My baby (car)
Oh, I was thinking weird, why dont people just buy an electric boost controller? Or get a stock solenoid unit and wire it up to a standalone like me?
[email protected]
themadscientist
hardware stor air compressor regulators work too.
AceInhole
95_240sx wrote:Oh, I was thinking weird, why dont people just buy an electric boost controller? Or get a stock solenoid unit and wire it up to a standalone like me?
[email protected]
Because if the electronic boost controller fails, or power to it fails, you get a lot more boost than you'd like, and risk detonation when you go past your fuel system's limits.
http://www.mcmaster.com sells ball and spring relief valves for around $7. Just need to tap the relief port to screw a nipple into it. Works on a 0-20psi range. Part no. 48935K25
