From the owner's manual:
PROGRAMMING HomeLink
To program your HomeLink Transceiver to operate a garage door, gate, or entry door opener, home or office lighting, you need to be at the same location as the device. Note: Garage door openers (manufactured after 1996) have ªrolling code protectionº. To program a garage door opener equipped with ªrolling code protection º; you will need to use a ladder to get up to the garage door opener motor to be able to access the the ªsmart or learnº program button.
1. To begin, push and hold the 2 outer HomeLink buttons (to clear the memory) until the indicator light blinks (after 20 seconds). Release both buttons.
2. Position the end of the hand-held transmitter 1-3 inches away from the HomeLink surface.
3. Using both hands, simultaneously push and hold both the HomeLink button you want to program and the hand-held transmitter button. DO NOT release the buttons until step 4 has been completed.
4. Hold down both buttons until the indicator light on HomeLink flashes, changing from a ªslow blinkº to a ªrapid blinkº. This could take up to 90 seconds. When the indicator light blinks rapidly,both buttons may be released. The rapidly flashing light indicates successful programming. To activate the garage door or other programmed device, push and hold the programmed HomeLink button - releasing
when the device begins to activate.
5. If the indicator light on HomeLink blinks rapidly for two seconds and then turns solid, HomeLink has picked up a ªrolling codeº garage door opener signal. You will need to proceed with the next steps to train HomeLink , completing the programming may require a ladder and another person for convenience.
6. Push and release the program button located on the garage door opener's motor to activate the ªtraining modeº. This button is usually located near the antenna wire that hangs down from the motor. If the wire originates from under a light lens, you will need to remove the lens to access the training button.
NOTE:
Once you have pushed and released the training button on the garage door opener's motor and the ªtraining lightº is lit, you have 30 seconds in which to perform step 7. For convenience, use the help of a
second person to assist when performing this step.
7. Quickly (within 30 seconds of pushing and releasing the garage door opener training button) and firmly push and release the HomeLink button you've just programmed. Push and release the HomeLink button up to three times to complete the training.
8. Your HomeLink button should now be programmed. To program the remaining HomeLink buttons for additional door or gate openers, follow steps 2 through 8 only.
NOTE:
Do not repeat step one unless you want to ªclearº all previously programmed HomeLink buttons).
If you have any questions or are having difficulty programming your HomeLink buttons, please refer to the HomeLink web site at:
http://www.homelink.com or call 1-800-355-3515.
My house was built in 2000, so I had to follow the rolling code procedure.
