Homelink Connection
Deke40
Car: 07 Nissan Versa SL HB 08
I tried to set up the Homelink in my wife's new Altima and couldn't get it to work. I decided to see when I had the garage door opener installed and low and behold I had it done in 1982. I guess it has been a good one but must be to old to work with the Homelink.
Been thinking about getting rid of the screw drive Genie because of the noise so I guess this will be a good incentive to do so.
Any recommendations on a type of door opener-screw drive-chain-or belt?
johnny_d
Car: 2008 Altima Coupe V6 SE w/ CVT
maybe but i tried a few times before it worked with my garage
Plastics
Car: 2007 Honda Civic EX, 1999 Dodge Caravan
Hey Deke I had a Chamberlain Liftmaster Forumla 1 -belt drive installed about 6 months ago and it works fine with the Altima homelink system. I had an old one like you, but it was starting to give me problems, once the electric cicuit starts to go, it would sometime not open....so I replaced it.
good luck
Plastics08 Altima 3.5SE Coupe Premium black
SHIFT_COUPE
Car: 2014 Infiniti Q50 AWD
Interesting how some things revolve around the new things we bring into our life. Buy a new car....have to buy a new garage door opener to use the feature
I have a car port type of garage with no door unfortunately. Good luck on your hunt!
AltimaJoe
Car: 2008 Nissan Altima Coupe 2.5S Premium Package
I don't even have a garage.
Deke40
Plastics wrote:Hey Deke I had a Chamberlain Liftmaster Forumla 1 -belt drive installed about 6 months ago and it works fine with the Altima homelink system. I had an old one like you, but it was starting to give me problems, once the electric cicuit starts to go, it would sometime not open....so I replaced it.
Stan
I finally retried programing the homelink and got it working. On my old remote you had to click it twice to close. I finally figured our if I clicked the homelink and held it a second or two between the two clicks I could get it to close.
Since I am such a perfectionest I opened and closed it one too many times and heard a loud pop and the motor was smoking. I looked up the date on the old Genie 820 and found out I had it installed 25 years ago.
Called and got a price of $295 for a Liftmaster 3280 belt drive installed with two remotes. The funny thing is that the old Genie cost $268 installed 25 years ago.
Thanks for the info.
PS-Got the Liftmaster installed and programed the homelink in the Altima and everything is working great. Sure is way quite than the old Genie screw drive.
Modified by Deke40 at 7:15 AM 12/14/2007
Modified by Deke40 at 4:01 PM 12/14/2007
