first i apologize if this is in the wrong spot. I have read on different forums the install for the homelink/autodim.compass mirror for our altimas and many other nissans. I am pretty good at figuring out what all is needed and how to wire (tap) into wires, but I would just like to make certain I am tapping the correct ones at the fuse block or prewired location. I have a 2013 altima coupe 2.5s with bluetooth phone and steering wheel controls for audio, that now has the homelink/autodim/compass install (just needs wired up) after close inspection last night I am pretty sure I have the prewire for it in the A pillar drivers side. there are two connector one is 16 ports total 8 on top and 8 on bottom and the other i am guessing is for sunroof i don't have. anyway right now i have 3 wires red 12v ACC yellow 12v constant and black ground ran down and taped off in the fuse box location under dash for now. I did find a wiring diagram for a altima sedan that shows all the connectors and wires for the homelink/autodim/compass mirror (as to which ones to tap or connect into). I will paste link on what i have found for the wiring diagram. http://www.nicoclub.com/FSM/Altima/2013%20Altima/
if you scroll down to the MIR.pdf its pages 4 and 5 that show the diagram. I just want to make certain this diagram will work or if anyone has done this any help as to connecting the 12v acc and 12v constant would be greatly appreciated. thanks mark
