What you want, especially with max's and i30's, is to divert/reduce the warm air coming from the radiator as much as possible. This is extremely difficult to do considering the placement of the air pipe is directly behind the radiator and the intake is directly behind the battery. Generally, PVC and plastics will work better than metal at absorbing heat; however, from a performance standpoint, PVC is not the best material to use as it has all kinds of ridges and bumps that will affect air flow. Does it really matter? Yes and no. Your airflow might be disturbed and performance might not be what you expected, but you will have less heat being transfered to your already warm air. Here is a write-up I did a while back: zerothread?id=281291AcMav wrote:Anyone care to comment on PVC vs. Exhaust tubing? I think PVC has a higher insulating value in comparison to the exhaust pipe, but it will melt easier. Does air also flow through the exhaust tubing with less resistance than the PVC? Any pros and cons here?
I have no clue what this really is. But I'm pretty certain its a drain for water that happens to find its way into the stock air setup. I just removed mine and put some industrial duct tape over it.AcMav wrote:Theres just a few questions i have.On my I30t the Air Intake branches off before it reaches the air box, one of the leads goes down below the battery to a box. I cannot seem to get a good view of this box and from what ive seen the FSM doesn't cover the intake. So what is this and do I need it? Thanks Guys
That is just random intake stuff. I took it off of my Maxima. Just makes no sense as to why it's there.AcMav wrote:Theres just a few questions i have.On my I30t the Air Intake branches off before it reaches the air box, one of the leads goes down below the battery to a box. I cannot seem to get a good view of this box and from what ive seen the FSM doesn't cover the intake. So what is this and do I need it?
AcMav wrote: I'm weary about placing it down low because i'm scared of Hydralock.
It takes a whole lot of water to hydrolock an engine. You would basically have to drive it underwater in order for it to hydrolock.
Gets rid of the whistling sound that people have without it.PBfrEAk wrote:OHHHHH....what the hell is that?!?!?! lol
mine does that too....sometimes. I just let it run like a muscle car for a few seconds enjoying the sound. Then everything evens out. I have a feeling I need to clean my intake and runners, but I've put off the runners because I'm going to get meviPBfrEAk wrote:Wow...apparently!!!
\\thread jack
Now here is a question for you...since you've done your intake...have you had any problems with it starting in cold weather.
When I start mine in colder weather (like, under 40) for the 1st time its fires up and dies. To keep it running I have to give it a little throttle for about 20 seconds.
Any thoughts?
//end jack
