Home made SPC caster rod
Luchitosan
Car: Nissan 200sx Ca18det 4 port
I want to improve the suspension of my S13 but need to be "streeteable"
so first buy this on ebay.... and installed on the car
DSC3030 por Luchitosan, en Flickr
Don't like at all, too hard to the streets of my city so talk to my Dad and he give me
an alternative solution: convert this into SPC Caster Rod style
First need to cut the oem rod at 11cm aprox to allow hold the piece on the Lathe
DSC04244 por Luchitosan, en Flickr
DSC04245 por Luchitosan, en Flickr
DSC04246 por Luchitosan, en Flickr
Then balance the part to position at the center of lathe
DSC04247 por Luchitosan, en Flickr
Need to lower the stick from 20mm (Oem piece) to aprox 17,80mm
DSC04248 por Luchitosan, en Flickr
DSC04249 por Luchitosan, en Flickr
DSC04250 por Luchitosan, en Flickr
DSC04251 por Luchitosan, en Flickr
The lathe made his job...
DSC04255 por Luchitosan, en Flickr
In the front of the rod is suggested lower slightly more (17mm or 16,50 mm)
to allow the next tool insert correctly
DSC04256 por Luchitosan, en Flickr
The size of the thread is 18x1.5 metric and then can cut the rod threaded
to 8 cm long or less if you need
DSC04257 por Luchitosan, en Flickr
The red regulator with the oem bushing is too large so need to cut the regulator rod at 11,5 mm
or you can put next to the oem rod (BEFORE YOU CUT IT) to make sure you measure right.
DSC04259 por Luchitosan, en Flickr
The finish product
DSC04260 por Luchitosan, en Flickr
The stick needs to be at 32,50cm from edge to bushing (similar to the oem)
DSC04261 por Luchitosan, en Flickr
DSC04263 por Luchitosan, en Flickr
Then you can sell the race type bushing ( the large of the stick thread is 4,7cm)
DSC04264 por Luchitosan, en Flickr
Salute !
Hijacker
Car: '92 240sx Convertible
'94 F-150
Awesome job!
Curious though. The cone shaped spacers (misalignment spacers). What are their dimensions? I'm curious on their outer diameter where they insert into the rod end and their overall length (they're combined lengths should come close to the width of the mounting bracket).
If you're looking for a slightly stiffer bushing as the factory silicon bushings will eventually fail, Nismo and Megan Racing have a press in hard rubber bushing that replaces the old factory bushings.
Luchitosan
Thanks you, if i undestand correctly you need the sizes of the red piece right ?
Exterior diameter and long ?
They' re placed in the car now cause align the car today, but anyway I can measure them still.
let me know
pepesilvia
Car: 96 S14
WOW! good work! You're mighty crafty arentcha? :bigthumb:
Luchitosan
Ohh thanks, but all the credit it's for my Dad he es the real crafty, I'm just a dreamer...
Luchitosan
Now the new problem it's in the rear suspension, cause it's too negative camber and the guy
who do the job show me in the aligner machine that the bolt to correct the camber is full register.
So this time i think need to get the SPC arms or any other that you guys recomend for street use,
NOT SOLID BUSHINGS !
Hijacker
'94 F-150
Luchitosan wrote:Thanks you, if i undestand correctly you need the sizes of the red piece right ?
let me know
No. The misalignment spacers go in the rod end that you didn't use.
Luchitosan
This is what you ask...
DSC04268 por Luchitosan, en Flickr
DSC04269 por Luchitosan, en Flickr
