Ever Victorious »
https://forums.nicoclub.com/ever-victorious-u44595.html
Sat Aug 18, 2007 7:09 am
The mesh look can work if applied right, which means that the upper grille also needs to match.
The "wrinkle" needs to be fixed if that's what it actually is, but to me it looks like something is behind the grille, and if that's the case, I don't think a mesh grille will work, because it will always look funny.
From what I can see, it looks like a cheaper, thinner grade of mesh. If it's not a permanent installation, you'll definitely want thicker mesh for the final version. Also, painting it either bright silver or black in the last stage would probably help.
Not bad for 20 minutes, though.
