Soravia wrote:Also, even if you push in cold air, your intake manifold will still be hot because of the coolent running by it.
And thats a good point why? Let me guess. You think that just because someone has an accuall cold air intaki (grabbin air from outside the engine bay) that it will have no effect on power cause the manifold will just heat the incoming air up to the same temp? PSHHHH! palease.......................... air heats up at a constant rate. I.E. if you suck in air thats already 100*F and your manifold heats it up to 150*F. If you suck in air thats 70*F it wont be 150*F when it enters the cumbustion chamber. It will be 120*F. Therefor, the colder the air going through the inake the colder the air will be in the combustion chamber. And we all know colder air is more dense. Dense air has more molecules in it. More molecules means more power. If you can add just a little bit more fuel in with all that denser air, even more power.
O.P. Spectre has a line of intake stuff you can use. They have a few styles of 90* bends, 60* bends, 45* bends, 20* bends, and straights. you can fab up just about anything with those options. Good luck and keep it ouside the engine bay. Or atleast use a heat sheild.
