x2elwesso wrote:PICS.
bullittandy wrote:This was a "retrofit kit" which consists of a bulb, ballast and wiring. The stock wiring is the input on the ballast which then runs to the new bulb. Its made for a H4 bulb and fits well.
Two downsides:1. You lose your high beams but I might try a Bi-xenon kit next on my 99.2. You lose the foglights as they are wired through the stock headlight wiring. I'm going to investigate this and I think it can be improved.
The above pics do not do it justice, the daylight pics make it appear that the light is shining incorrectly but its really just the camera. Head on they just appear very bright. At night the brightness is amazing.
Again, this was a $80 kit off Ebay Xenonautohaus was the company I think.
elwesso wrote:Honestly do you think you need the high beams with these lights?
NightRiderQ45 wrote:those pics are great. I was looking into getting an aftermarket hid kit. I'm still searching for the hid with the casper shields. If not, local shops here will aim them downwards so they won't blind. I think that's your situation Romeo.
I don't get why your fogs aren't working. I'm on my 3rd xenon kit all from different companies and my fogs never went out. I have a 97bullittandy wrote:This was a "retrofit kit" which consists of a bulb, ballast and wiring. The stock wiring is the input on the ballast which then runs to the new bulb. Its made for a H4 bulb and fits well.
3rd kit!? What happened? Did the pervious bulb go bad or just kept changing different lighting (k temp)? I'm going to purchase the bi-xenon, do yours have the shields on them?Solini wrote:
.Qproject wrote:go for the bi-xenon capsule type, they have good coverage just like a casper shield.
Who installed them? The wiring is strange on the headlight harness, the ground wire is energized when the headlights are turned on.Solini wrote:
