nissanfanatic »
https://forums.nicoclub.com/nissanfanatic-u21678.html
Tue May 03, 2005 3:18 pm
Just do it correctly. Even if it is a pain to get it started. You have to or you aren't doing it correctly which means you can't compare to the FSM standards. Their standards were taken under different conditions than you are testing. Apples and oranges here.
I count to Five one thousand while cranking. The main thing to look for is how quickly the gauge "jumps up". If you are cranking and it is slowly creeping up, then you are getting a lot of leakage. If it comes up quickly, you have little leakage.
If you can, get access to a leak-down tester. You can listen for where the air is leaking. But test under the same recommended curcumstances as you would compression test.
Check your gauge out too. I used one from a friend that gave me 160psi readings. Bought a new one from advanced auto parts, an "Actron", and it showed 180psi across all four.
Good luck.
