You have a NISMO unit correct? If so, I had one die on me and I kept it as a souvenir. It Gave silly fp readings at around 40psi and I have to crank it up to 85psi just to run the car. The thing completely showed it's butt on me on the dyno. Put a stock one back in while the car was still on the rollers and went on to produce 332whp@20psi.rico05 wrote:So, today was a really chilly Tejas day. I went to start my car, and it died 3 times after about 2 sec of running. Hmmm. Started 4th time, and wouldn't idle, so I gave it some gas. The car ran really crappy, and a HUGE cloud of white (gas) smoke enveloped my car. Well, after careful modulation, rock solid idle showed up, and all was fine. I popped the hood, and took a look at my FPR pressure gauge, and low and behold....40psi! So, that is ~5psi more than it should be. Is it b/c the car was stone cold? Did my FPR finally die? When I put the gauge in in summer, it was reading 36psi, and I noticed it seems to be increasing a little bit ever once in a while. So, thoughts?
Who me!float_6969 wrote:did the jam nut loosen up on you?
It's fairly simple, but as for simplicity of scribling color codes to accomodate everyone, it'll have to wait until I wire the S13 that I'm about to drop a CA18DET swap with bigger turbo, better manifold, intercooler, blah-blah-blah. It's a full project that I've been dispatched to handle, so when I 'm done or crosss that area, I'll be sure and scribble down what I did with the re-routing of the fuel pump's power supply.rico05 wrote:Care to include a procedure on how to do this Dee?
ehh? is this a common problem?float_6969 wrote:Simply upgrading to a walbro was overruning my stock FPR.
Completely possible. As I said before, I was simply speculating.top_secret wrote:where did you guys get this variable voltage scheme? I know the Z32 has it, it has multiple wires for it... the S13 just uses a 12 volt relay and a single power wire... I thought I read a while ago that US 240sx's don't have variable voltage... I'm pretty sure they don't, in fact.
