Holy crap! 915 bhp SR20DE!
For discussion of front-drive SR20DE, SR20VE and SR20DET engines!
Swedish Mike
Car: Golf TDI, Volvo 850T5 and 200sx S13 Hatch
Just bought the Swedish magazine Bilsport, usually boring but this time they had an interesting car featured!
Nissan Cherry Turbo "Wok Edition"
SR20DE engine from Nissan Primera GT:
*JE pistons*Saenz rods*Stock crank*Stock valves*Custom cams*Springs and retainers from Kelford Cams*Custom intake with 75mm TB*Iveco truck IC*3.5" exhaust*Custom tubular manifold*Garrett GT42R turbo*Dual Bosch -044 pumps*Bosch 1600cc injectors*Autronic SMC standalone
Result: 915hp/883Nm at 2.9 bar.
transmission? Volvo 850 5-speed gearbox and axles. Volvo brakes as well.
Best ET: 10.18 and 236 km/h at the first try, more after the winter.
Modified by Swedish Mike at 8:54 AM 12/22/2006
nametakennow
Car: '06 MINI Cooper S
Sadly, that power comes at 11 billion rpm.
Still, this DE+T proves that the SR is one hell of a motor.
Swedish Mike
nametakennow wrote:Sadly, that power comes at 11 billion rpm.
8300 rpm actually. More info and photos in SR RWD forum, wanted them to see as well.
nametakennow
8300 with the sort of turbo lag I'd expect out of a GT42 would take an awful long time.
I still thing a GT30 or 35 might yield a better 1/4 with a larger powerband, but again, this is cool.
Swedish Mike
nametakennow wrote:8300 with the sort of turbo lag I'd expect out of a GT42 would take an awful long time.
420hp@6200rpm and 915hp@8100rpm, crazy...
corey240
Car: 1993 Nissan 240SX Base Drift Machine
technicaly its not an sr20de anymore, its a T. still cool as shizle though
Logan76
Car: Junk
That much hp and only 10's in the quarter, someones not hooking up
HurryupandrunS13
Car: 1992 240 fastback
lll
Logan76 wrote:That much hp and only 10's in the quarter, someones not hooking up
LLLAAAAGGGGG!!! that's it, and when he finally hits max boost it probably spins like a MOFO. On a +60mph roll, that thing would BEAST!
Swedish Mike
First test run on low boost, takes time to adjust and make everything work. Can´t say it´s bad, most guys wont hit a low 10 in a life time.
I´ll report here this summer, very close to race season.
200SX_SER
Car: B14 200SX SE-R
hell of an engine! what is low boost? you posted it makes [email protected], is that right? 2.9 bar equals about 41-42psi, is that even possible? whats the compression ratio? also post a pic or two here plz
Mazworx
I think the GT42R is the perfect turbo for the SR20. That's what we run on our race car and it response very quickly. Going to a smaller turbo will make less power, so how can you expect the car to go quicker? Why are people so scared of big turbos?
Logan76
Car: Junk
Almost all big name tunning companies run, 40R's and 42R's, its how you make power, look at AMS's EVO thats running 52lbs of boost out of a 42R (I believe I read that in a magazine, correct me if im wrong). A big block with 650hp is running low 10's though, thats why I said for all that HP those times were'nt that good.
nametakennow
In a straight line, having more power is pretty much always a good idea.
However, if I were actually driving the car (yaknow, that stuff that involves turns) a 42 would be pointless and stupid.
Swedish Mike
I think he ran 18psi at the 10 sec run.The Madtech S14 boosted 3.25 bar.
Logan, he ran 400hp something that time and just took it out from the garage, we will see crazy ET´s from this car.
Master Chief
Car: Nissan S14
The swedish guys make tons of power from SR20's aperantly.... Meaby its something in the food there.....i want some too
Is that power on STOCK OEM SLEEVES ? I know Madtech got 850ish in stock Sleeves, just curious about these guys ?
chan
Swedish Mike wrote:Just bought the Swedish magazine Bilsport, usually boring but this time they had an interesting car featured!
nice ,sick setup
HurryupandrunS13
What A/R is that 42? Just curious. Also, that AMS Evo (one of many) put down, I beleive, 988awhp on 42-45psi, somewhere in that range.
3.25 bar........?!?!?!?!
Swedish Mike
Master Chief: Yeah, stock sleeves.
HurryupandrunS13: Turbine A/R is probably around .90 to 1.05.
Don´t know why but our dyno´s always show lower numbers at the same set up.The tuning shop can adjust the dyno to show more or less hp in % and I guess our companies set them low to be safe or some US companies set them high to make the customers happy.
One example: A Volvo 850T bottom can handle around 330bhp before the rods bend, in USA we see people dyno 330whp without even tuning them correctly.When you compare the cars we always put down higher trap speeds with lower hp on paper.
HurryupandrunS13
I recently Googled MadTech S14 and man o man! I have seen that car on the internet before but never specifically knew it was that one. SwedishMike, do you know those guys? Does that Cherry turbo have any videos on the net?
Swede_gtir
HurryupandrunS13 wrote:I recently Googled MadTech S14 and man o man! I have seen that car on the internet before but never specifically knew it was that one. SwedishMike, do you know those guys? Does that Cherry turbo have any videos on the net?
Here is a video with the Cherry turbo
http://www.youtube.com/watch?v=ZharhITbEb8
HurryupandrunS13
Nice! I love the first pull at 14 psi, that GT42 probably didn't even know it was spoolin!
DisBeBrand0n
Car: '97 200sx SE-R / '91 240sx fastback
thats pretty impressive.
Weber3211
Car: 1991 Nissan 300zx
damn... is traction even possible at that point? haha
lumpy
Car: 1997 200sx w/ sr20det
I love it!
Blind Drifter
Car: 1JZ MKIII Supra and Starion
Nice. Id like to see it full out. Shoot, broke a intake manifold on low boost.
turbonxsx
damn
dhessian
Car: 240sx
Awesome
aea-1919
holy crap!
conenubi701
Car: 1998 Nissan 200sx SE-R
Spin City!!
SxMachine
Car: Im on a horse
Wow. Guess i'll be buying a 4th car. Time for that b13
Return to “SR20DE / SR20VE / SR20DET Forum (front drive)”
