KEMP »
https://forums.nicoclub.com/kemp-u119247.html
Wed Apr 01, 2009 6:02 pm
so i pulled the head tonight, to find a blown cometics, leaking in all cylinders and in journals.
it had peices of the gasket broken aoff in small peices around the cylinder holes of the gasket.
the cylinder walls on the inktake side have slight scoring, but only towards TDC. the pistons have slight play in them, to where i can wiggle them a slight bit.
the rings are toast, since the outside of the piston top are cleaner than the inside, or atleast thats what i was told.
i believe it was possiblt piston slapping, im not sure, there was score marks and i have no idea why, and only towards TDC stroke.
the head, ahh the head, has almost a lip around each cylinder, like an edge that should not be ther, damn near sharp, no too noticable until you feel it, but its there, i have NO idea what the hell happened, i am sooo stumped.
the head gasket on the cylinder part had peices missing, VERY small peices, and one was still attached, i could pull it off like a metal splinter, it almost sounds to me like a piston hit the head on every cylinder, but valve are five, and the pistons do not raise above the top of the block, the top ring seems to be fine, i can see slightly down the walls between the piston and wall and catch a glimps on the ring.
please help me, i have literally no idea what to do, or where to start, the people who built my motor are getting a big peice of my mind tomorrow, they failed on something so hardcore its not even funny, like literally the WHOLE motor needs redone, HG, head, block, idk what else.
where do i start? any ideas what happened
