Holset on Rb20?
moso240
Car: Ferrari V12 Powered S13
Well My rb20 is completly stock with a 255 walbro fuel pump. I had a AEM EMS installed and tuned at around 18 psi but on the stock turbo people are telling me im lucky it hasn't gone ka-put..Im dont know so much about turbos in specifics so please be noob frindly.. SOO I want to run either a HX35 or HY35 but am unsure which on will benifit me more in the long run.Also are the holsets direct bolt on? if not what has to be done to make these turbos run on the rb20.. your help is greatly appreciated
Cameron
Car: a 240
Yea i told you that turbo will blow sooner or later... your insane. Holset Hx35 for you
/thread..
Good for more power than you need.
how old are you btw? it says your 14.. who bought you an RB?
oh i see your a rich kid.
moso240
ok hx35...how is the install tho what needs to be done? it cant be as simple as bolt up and your good to go
Cameron
Car: a 240
im not too sure. i would think that it would fit the stock mani, but the wastegate deffinately wouldnt.. i would get a new manifold.. plus the wastegate is set for around 21psi i believe so youd be better off getting a 60-1 and calling it a day.
moso240
Hmm....is there anyway I could make it all clear with the stock mani...Im on a budget of like 570ish...
Cameron
Car: a 240
prolly only if you went external wastegate. idk of anyone running internaly gated holsets on an RB.
moso240
ok lemme get this striaght if i buy a rebuilt hx35 all i gotta do is undo the internal wastegate replace with a tial wastegate? with no mods to the turbo housing wise?
Cameron
Car: a 240
that is correct except for weld the flap shut. and make a flange on your manifold for the tial. id go 38mm.
you might try the same place he got his done at. or i could sell you a stock manifold for $50 and you could hack it up and not be worrying about damaging yours if it were to crack.
zerothread?id=308501
also search nico for holset. a lot of good info on that search. only do the ones pertaining to RB forums though or you wont get what your looking for.
moso240
Awsome thanks for your help.... You think 550cc Injectors would go nice with the turbo?
Cameron
Car: a 240
how much power you looking for?
moso240
high 3's
Cameron
Car: a 240
yea 550s will be fine.
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
ZenkiCam wrote:Yea i told you that turbo will blow sooner or later... your insane. Holset Hx35 for you
/thread..
lol. If you can get bigger injectors get bigger. I'm running 800cc's on mine for 1billion JDM horses.
SeVa-S13
Car: '05 GTO 6spd
Newb, you're forgetting about JDM to USDM HP conversion rates. He only needs the 720cc's for 1.27 bazillion usdm hp.
mott6904
Car: rb20 big turbo big cams s13, 97 kouki, turbo audi a4,turbo busa
haha...you might want to search... there are plenty of threads that give details on what has to be done. If i remember right there is some custom stuff like welding that has to be done. I went with a 60-1 and love it. After building my car ,if you cut corners and that part is complete you only save a couple of hundred for something that is thrown together. Just my 2 cents
Cameron
Car: a 240
yea if you dont have enough money to do turbo, tap for an external wastegate, buy a wastegate, buy new injectors, than just go buy a 60-1 and get new injectors.. mott is right. Holset is for the DIYer
DriftX
Car: '89 240sx
Custom oil feed and return lines...Converting internal to external wastegate...welding an external to stock mani...custom exhaust work...
Hardly for a newb that doesn't even know what size injectors to run.
/thread please.. he needs to search.
moso240
i asked for opions on which injectors to run wtf i never asked for your bull****
/killthread
mott6904
moso240 wrote:i asked for opions on which injectors to run wtf i never asked for your bull****
/killthread
Lets see when you can search instead of asking questions that get answered all the time then you wont get "bull****" You started off asking the difficulty on putting a holset turbo on your car which turned into another question everyone is tired of answering. Hence, the reason why you get smart*** answers, If you can handle that then you are on the wrong forum....
