Holset HX35W turbo????
Nismo94
Car: 1994 240sx convertible
Just bought a 240sx vert with a KA24DE, it came with a Holset HX35W is that a pretty good turbo to thro on the KA at 10psi? Would it run pretty good and strong? Feel free to put any input you have. Thanks
Modified by Nismo94 at 1:12 PM 7/9/2007
Swedish Mike
Car: Golf TDI, Volvo 850T5 and 200sx S13 Hatch
Nismo94 wrote:Just bought a 240sc vert with a KA24DE, it came with a Holset HX35W is that a pretty good turbo to thro on the KA at 10psi? Would it run pretty good and strong? Feel free to put any input you have. Thanks
Holset is hardcore stuff. In good shape? Still stock WG port and actuator?
I´ve used both HX35 and 40, great turbo´s.
Nismo94
Ya its in good shape comes with an inter cooler, but i need to replace my headers, and get an exhaust while im at it, i also have to get a waste gate to keep at 10psi.Probably need to grab a BOV.
the actuator i'm not sure ill have to ask the guy i bought it from and check.
Swedish Mike
The reason for asking is that the HX35W´s I´ve seen have internal WG and way to small port for a gasoline engine.Without porting and new actuator it you´ll loose the boost control.
The regular HX35 is a straight turbo without WG.
Nismo94
So i need to ask if it has a if it has a WG?
If it doesnt should i be fine as is?
Swedish Mike
Nismo94 wrote:
The regular HX35 is a straight turbo without WG.[/QUO
Yeah, if it´s a regular HX35 you can use external WG like Tial, HKS, Turbonetics....
If it´s a internally gated you can plug it and go external or just open it up and use it.The good thing with the internal is that you got the WG in a good location from start and no extra holes in the manifold.With some love you can make the internal perform good enough for the turbo size.
Also ask if it got the #14 turbine housing, good spool up and T3 flange.You can see the number casted in the housing.
I hope you understand my crazy language..
Florida240sx
Give us pics of it
Nismo94
Florida240sx wrote:Give us pics of it
will have those into u by wensday
WDRacing
Holset makes a quality product...
