Anyway, noticed my oil was a bit low when I went to change it. Found a 'gash' in the oil pan- not much, but evidently *just* enough to allow some seepage. Really doesn't even drip.
How should (or can) I fix this?
Sure, drop the pan and change it. f-me...
Can I weld it in place? (Hey, gotta ask) I've got a wire feed welder with shield gas... drain all the oil, clean the 'wound', weld, buff, paint... then flush the pan to get any carbonized oil out?
Any particular concerns with using current around the engine on the other electronics?
Any thoughts? Is this really stupid?
Thanks
Adam
