Hole in Firewall to pass through?
PoorManQ45
Is there a place on the firewall of the Q that I can pass a 1/2 part through? I have looked all over but can find anywhere to send it through.
Is there any way to get the part from the cabin into the engine bay without drilling a hole?
If not, where should I drill a hole at?
The part I have to send through the firewall is an aftermarket Coolant temperature sending unit. I will be using the hole right behind the water filler neck where the OEM unit is.
Any ideas?
You should be able to just run the wires through, right?
zinkie13
Car: 1992 Lexus SC300 Single Turbo
I don't know if you car is different or not, but I ran a 00 gauge wire through a hole on the passenger side. It was extremely tight, as there were many other wires going through it. I first had a 4 gauge wire running through it for my stereo and taht took about 2 hours to get it through. Then this summer I moved my battery to my trunk and used the 4 gauge to drag the 00 through. Worked like a charm.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Check the article on Q45.org "wiring a sub/amp to bose"
theres a couple holes on the drivers side...... right where the hood cable goes to..
