vancouverbc »
https://forums.nicoclub.com/vancouverbc-u10923.html
Mon Jun 27, 2005 7:28 pm
You'd have to buy silver solder or silfoss. Sliver solder melts at lower temp so you can only use it in the part of the system that does not get hot ie low side if i remember right. You have to get the copper cherry hot before silfoss solder melts. A butane torch might be hot enough but an oxy/acet torch is much easier. You'd also have to replace the filter. it's only 10 minutes labour for someone who knows what they are doing. you need to cut the tubing expertly or you will deform the tube, leave a burr on the inside which will impede flow of refrig. you will also likely leave copper fragments in the tubing which is a no no. it takes quite a while to learn how to silfoss solder right. i don't think you are saving much by doing the soldering yourself. your soldering efforts will likely introduce more contaminants to system. any air, moisture, carbon, metal filings, etc is death sentence for compressor once it is operating .
Modified by vancouverbc at 6:40 AM 6/28/2005
Modified by vancouverbc at 6:41 AM 6/28/2005
