MainEvent212 wrote:
why do you think that when you watch D1, when they transition, the smoke dosent stop? Because they are transitioning under throttle. Dont let off, no ebrake.
Further more, to correct the E-brake statement. Generally the E-brake is to initiate far ahead of the turn for straight line initiation. Also, it's used to adjust angle a little bit, not to change directions at all.
Watch any in car D1 footage and you'll see that throttle lift DOES occur and ebrake drift extensions DO take place and the smoke never stops. It's for the same damn reason the smoke is still pouring out of their wheel wells and cockpit long AFTER they've already driven off the track though...becuase there's so much of it! 400whp+ and baller *** tires = loads of smoke.
Consider the e-brake a tool. You can use it more than one was, as do most d1 and pro level drivers. You can initiate, correct angle, and extend drifts.
Do you know why ebrake is used for early initiations? For the same reason D1 and pro level drivers sometimes use it during a drift...to extend it. Sometimes throttle just won't do it. Nobody takes a perfect line every time. I agree that it seems like he needs to stay on the throttle longer, but don't mislead him. EBRAKE WILL EXTEND YOUR DRIFTS. Especially in the example he posted where he's going from on turn (left) to a straight and then another turn (left). Before you try to mash the trottle all the way through, use the ebrake to extend it. It works. No ebrake for transitions though. That would be weird...and bad.
