GoinTopless240 »
https://forums.nicoclub.com/gointopless240-u37872.html
Tue Mar 16, 2010 3:52 pm
Hey man,Good to see you're back. Hmm.. to get that feel? Yes shocks, tension rods, control arm/bushings front and rear, sub-frame bushings, motor and trans mounts. Oh and a sometimes overlooked one... tires (check the age of them - last four digits of DOT number xxxx xxxx 3508 would indicate 35 week of 2008). Worn tires also ride hard (thin covered steel belts=harsh ride). Sub-frame bushings are a PITA to switch out. I'm gonna switch mine out last. Good luck getting going again. Good to see you back on.
