bentvalves »
https://forums.nicoclub.com/bentvalves-u46428.html
Sun Dec 16, 2007 4:51 pm
Fill your factory engine and transmission mounts with window caulking.....I believe its what they use. Alot of them dry flexible and are meant to be that way, others cure to be rock solid, the later is obviously what your after.
Theres a writeup on zilvia that tells you EXACTLY which caulking to buy at the depot repo.
This would be easier than the pucks, take you less time, and if your crafty about it, its not as hacky as you might think.
