Anyone familiar with these? I read online that you can use one in conjunction with a MBC. Set the MBC to over boost, say 18psi, then have the hobbs switch set to your desired boost, say 13psi. From what I gathered, you'll spool up quicker because the mbc is set higher, but the hobbs switch keeps it from over boosting.
I was wondering if you could just use the hobbs switch without a boost controller, and just set it to your desired boost, in conjunction with a toggle switch turned on, then with a toggle switch turned off, you'll just make stock boost. Will it work this way as well?I've seen them on Ebay with 2 vac ports like this one
http://cgi.ebay.com/ebaymotors...ZWDVWand also with 1 vac port like this one.
