hmmmmmmm????
Bodge420
Car: 1992 Infiniti Q45a
Im looking at buying RWD 22x9.5 inch rims, I own a 1992 infinity Q45a, the bolt pattern matches but do you think it will fit?? will raising the suspension help?? is there anything car specific I should know??
Falkdesigns
Car: 1998 Q45t ~ EXE
Yeah man, raise it up about 4" with a Skyjacker lift kit, and then you could even run some 28"s!! All in the name of the largest possible wheels that you can buy. BTW, there's no Y in Infiniti.
Here's a clown car to give you a good idea
Bodge420
oops with the y, haha, long day, that would work, but do u think they would fit stock?? i have 20's that fit fine, i was wondering if I raised the suspension with the stock airbags in the 92Q45a without actually adding a lift kit if it would fit or should I assume that if they dont fit without the car raised they shoudlnt be on period?? thanks again
2005Q45inCali
LOL @ Falk
Honestly I dont think they will fit on a G50 (92 q) because they barely fit on my 2005 Q without modding or cutting. I can actually go 22x10 in the front because the wells are so big. But Im sure if you wanted them to fit you would have to trim the inner fender and the front wheel well. But what do i know... theres a early model Q on cardomain with 22's and on the website superbuytires.com.
But seriously the early model Q's werent designed to handle that big payload and stress on a car. Your car is around 15 years old or older and they will decrease whatever life you have left on it significantly. Stick with 19's or 20's and call it a day.
Bodge420
will do ,Qincali, im rather partial to the 20's and if it involves any trimming im all set, also im thinking about replacing the front left tire rod and control arm, should I do it myself or dealership??? would I be getting in over my head?anything car specific I should know? thanks again
2005Q45inCali
if you start replacing the tire arm and all you will be spending more than the worth of your car... yes you will be getting over your head. Just wait till you start to replace your pads, rotors, struts, etc
mcastro
Car: 1995 Q45
Your tire would probably end up hitting the third link in the front suspension; I don't think you could mount them even with offset adjustments...
CrimsonQ
Car: Purple People Eater
Plus itd be a damn shame to have your Q slowed by the weight!
20's look damn big to me on a G50. although my 18's seem small sometimes
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Man, that Mary Kay bride of Frankenstein Q45 on eBay has a cousin!
Too much inbreeding in that family.
ddrumman
Car: 08 FX35 39,000 mi, 07 G35 55,500 mi, 72 MGB
CrimsonQ wrote:......although my 18's seem small sometimes
Man your car looks just right.
Falkdesigns wrote:Yeah man, raise it up about 4" with a Skyjacker lift kit, and then you could even run some 28"s!! All in the name of the largest possible wheels that you can buy. BTW, there's no Y in Infiniti.
litlchi
HAHA! I like how the wheels are almost bigger than the car! Now all he needs is to get some studded off road tires and he'd be set.
Q451990
And from the title I thought this was going to be another fuel pump thread!
Heath
