Hmmmm...S11 or earlier Silvia?
Here you'll find topics regarding the Datsun B210, 310, 610, 710, 810, 1200, and lots of other models - All are welcome!
BB Turbo
Car: 2007 Nissan Titan KC
1992 Nissan 240SX Coupe
Well, since this is vintage Datsun, I would like to know if there are actually any mods you can do to any of them and what engine did some of these come with and what are the specs. I guess I will write a thread on the specs or a FAQ. Like S12 and below. Off to do research.....
BB Turbo
Haha, nobody except the mods will ever see the FAQ but I will do it anyway
McAdam
Car: I like cars and my motorcycle. boats are fun too
Hello there most of the early 200sx's came with L20B motors and the Z series motors. up until 1984 I beleive, then they came with the CA series motors. The L20B and Z series motors were similar in block design, but had a different head. The L20B head was great for NA application, as it lent itself well to porting, polishing, and biiiig hairy cams! and L20B head WILL bolt straight onto a Z series block. Just ask ANY 510 guy, there are plenty of sites out there. The Z series heads were more for emissions than performance, sure they are crossflow as opposed to the L series sideflow, but they have low port angles, and if you put big cams in them with big lift, the valves will hit eachother!! ANd not to mention you really can't go too crazy with the porting and polishing. the early 200sx's had a 4 link solid axle rear suspension in the back, wich handled decent but really lent istelfto drag raging. Not sure on teh fronts tho. Hope this helps!
drunkmonkalan
the turbo model 200sx's have independent rear suspsion btw... if only i could find one =(
jjwilks240
Car: cars
i have found a turbo 200sx in a junkyard in southern ontario canada, i have heard that the exhuast manifold bolts up to a sohc 240, but ports need to be shaved... anyone know anythin about this
Datsun411
Car: 1967 Datsun RL411 Super Sport Sedan
General FYI (not yelling, just info)...
The model you're talking about doesn't belong in this category, this would be 'Modern Datsun' if labled 'Datsun', not sure where if it's a 'Nissan'.
And yes, I know the '60s (vintage) Silvia was a Nissan, not a Datsun.
Point to this is you're more likely to find kindred fellows in the right forum.
Take Care & Enjoy,Carl
Return to “Other Datsun Cars”
