hmm ya know - timing chain - but what about my transmission :(
xcrazymike
Car: 1991 Q45
i'm broke as can be due to bills, but what about my transmission - prefer you're rather interested in the transmission problem than the timing chain - i know nothing about my 91 q45 and i need help;;; i don't know anything prior about my car, except it was bought in miami - seems as if the a/c belt snapped off so i don't run the a/c, my steering loses fluid or so it seems and every so often i fill it up with fluid - i have 191k miles on it - *sigh* i guess you can call it slipping for my transmission, 80% of the time i accel, it seems like it's stuck in first gear, alot of the times i'll accell on the highway and the rpms go up b4 the tran shifts, and i hear a -click- sound alot...? help me save my car by your expertise, i beg of thee ((((( spank u
Mike
This is the wrong car to own without the resources to spend. My advice is to sell it.
Now to answer your questions, first check the articles at http://www.nicoclub.com.
You might be leaking transmission fluid (ATF is used in power steering) from the high pressure hoses, low pressure return lines, or the rack itself.
Do a search on "chain guides". YOU MUST DO A SEARCH ON "CHAIN GUIDES"
191k is a long time for the Q transmission. Small things like jerking, hard shifting, and funny idling can be fixed with a flush, but if its dead or slipping, its toast.
Again, sell the car unless you really, really love it and are willing to commit time and energy.
Modified by Jesda at 8:43 PM 5/3/2007
Haitian_King
Car: 1992 Black Infiniti Q45 /w TCS
1995 Black Infiniti Q45
What he said.
Q45tech
The least expensive junkyard take out will be $500 [and boy are you gamb|ing because it may be worse or no better] JDM takeouts [lower but almost all Japan city miles] are usually $750 pickup in Atlanta.
Then the 5-6 hours of installation labor. Twice if you get a bad one first time.
Driven into ground Q often need $7-10,000 to get back to normal but most don't know normal without purchasing new.
We buy running junkers for $500 delivered for parts.
96Qowner
Car: 1996 Q45
You can try a couple good flushings for the transmission - might help, probably won't fix it, but a replacement is gonna run $3500 or so - a professional flush is just over $100. Get it flushed, see what happens.
