hmm which temp gauge for oil and which for water?
Fenvy
Car: 2005 350Z Base 6MT
yeah I got a defin din gauge
it has 2 temp gauges, one of them is 30c to 150c and another is 50c to 150c... which one should I use for water and which for oil?
also where do I install the oil pressure sensor? on the s13 sr20det motor, I feel something sticking out on the left side of the oil filter, it's covered in a rubbery thing too, is that it?
Nismo_Freak
Car: 89 Nissan 240SX
Loveless wrote:yeah I got a defin din gauge
I'd use the wider sweep for the water temp.
Yes the sensor is directly about 1 cm to the left of the oil filter.
Fenvy
need to remove the starter to get to it... it's a *****
Modified by Loveless at 9:49 PM 11/7/2004
Fenvy
the water temp sensor will not fit... I'll need an adapter too
silkk
Car: 94 B13
89 S13
07 S2000
That looks pretty good. Good luck on hooking it up!
Bronze MFP
Car: 1987 Nissan 300ZX w/digital dash radness
thats makin me drool. nice choice was it hard to wire up?
Fenvy
the gauges themself installs like a radio, except easier... only 4 wires to tap: ground, constant 12v, ignition, illumination
routing the sensors to the cabin isn't too hard either, I zip tied all 3 wires togehter and put it through the firewall somewhere and got it out from the passender side dash
the sensors... I had to switch out oil drain plug really fast to get the oil temp sensor in without losing too much oil. Water temp didn't really fit so I put the stock one back on. oil temp is a ***** since I can't get to it at all so I removed the starter first and then the sensor is easy to get to.
