Hmm.... running rich
ZOMG.SR20
Car: 1990 s13
My car is running but not really because of this problem of a rich fuel mixture
http://www.youtube.com/watch?v=nJxVJU4BaTk
and the Idles off but I can deal with that
http://www.youtube.com/watch?v=Tl7FYIBVuIc
new FPR
New fuel filter New Fuel pump New injectorsnew MAF New IACV
so WTF?
it revs fine but as the idle comes down the mixtures stays rich and when it gets to 800 it stalls out and now it wont start back up at all
the car will crank fire die then I crank it and it just cranks and cranks till i un hook the fuel pump and dry out the cylinders the it cranks and fires and dies
Chris28
Car: 92 s13 KA-T
Injector o-rings?
Do you have a wideband to confirm that you are running rich?
I thought only the mods had that avatar.
ZOMG.SR20
Car: 1990 s13
those is new also
ZOMG.SR20
Car: 1990 s13
i have a hunch its my O2 sensor since it doesnt matter whether its plugged in or not it still does the same thing
kouki munster
Car: 97 base 240
I was having the exact same problem, no bad sensors, injector o-rings good, proper fuel pressure, ect... It was just dumping crap tons of fuel and flooding out and wouldn't start.
The only cause that I could come up with was that the ecu took a poop, so I sad f**K it and bought a haltech, installed it, set it up, changed nothing else, and bam cranks up just like it should and was running like a champ untill I popped a ringland a couple days ago.
ZOMG.SR20
Car: 1990 s13
I have a New stock Ecu....
nightsauce
Car: 1991 Nissan 240SX S13 hatch RIP
1992 Nissan 240S S13 hatch :D
ZOMG.SR20 wrote:I have a New stock Ecu....
yea, straight from nissan? how much did ya fork out for that one....
mattblancarte
Car: 2005 BMW M3 Comp. Coupe
What kind of injectors are in there, again?
Sounds like the tune is pooped on the stock ECU, or you have leaky injectors of some kind.
Who knows, though.
mRodiek
Car: Stock Hatch
http://www.240sxforums.com/for....html
Something to try out, Im dealing with the same issue and Ive used 2 different MAFs and no change-Im trying the coolant temp sensor next then a new FPR.
kouki munster
Car: 97 base 240
Why don't you download a sr fsm and check to see if your cts is bad or your fuel pressure is off, instead of just throwing parts at it.
Op try a different ecu, or try your ecu on another sr.
ZOMG.SR20
Car: 1990 s13
100 shipped
mattblancarte wrote:What kind of injectors are in there, again?
Who knows, though.
370cc SR injectors that were Flow tested by DW
DriftBoy07 wrote:http://www.240sxforums.com/for....html
Im going to go through all of that tomm
mRodiek
Car: Stock Hatch
$100 FROM Nissan?
ZOMG.SR20
Car: 1990 s13
I has friend that works in Nissan Dealer
xX RB Xx
Car: SE3P, FC3S, FC3C.
im calling
so proof please
ZOMG.SR20
Car: 1990 s13
its a code 63 ECu the Automatic ones are cheaper
but seriously I bought it from someone in the Nico classifieds
I already tested it in a running car BTW
xX RB Xx
you liar!
ZOMG.SR20
Car: 1990 s13
lol
kouki munster
Car: 97 base 240
retard from other site wrote:AAC/IAC: The AAC valve (Auxiliary Air Controller) takes in the air ratio and puts it through the computer keeping a tab on how much air is entering the intake. Mostly it is the ECU's main idle control system and can deff control the A/F ratio.
WTF is this a$$ talking about? The IAC/AAC has 0 control over the A/F ratio, it just controls the idle speed by controlling the amount of air being allowed past the tb when closed.
The others are a good basic suggestions of what to look for if you are having problems running rich.
ZOMG.SR20
Car: 1990 s13
it controls the air into the intake in order to Idle hence AF ratio
mRodiek
Car: Stock Hatch
IDLE Air Control Valve...hence controlling the idle, but I have heard from multiple sources that it changes the AFR as well.
ZOMG.SR20
Car: 1990 s13
idk but i has new on of those also
kouki munster
Car: 97 base 240
It controls the air being allowed past the tb, the only effect it has on mixture, is when it allows more air in the maf sees more air going past it, and the ecu increases the injection time accordingly to reach the target afr. The same thing happens when it decreases the amount of air being allowed past the tb, maf sees less air, ecu decreases injection time accordingly.
It has no control, it can just cause a very small change(if watching it on a wide band .1-.2 change) in the afr that is immediately compensated for.
Koshin
Car: JP'd out Y32 Nissan Gloria GTU
750 hp '87 Buick Grand National
'63 Chevy Impala SS 327/4 speed
lol @ the OP
kouki munster
Car: 97 base 240
^Can I have your gloria?
